Knowledge Base Article
Why is the Intel® Stratix® 10 E-tile Hard IP for Ethernet (10G/25G) TX Timestamp error > 1 second?
Description
Due to a problem in Intel® Quartus® Prime Pro version 18.0 and earlier, the Intel® Stratix® 10 E-tile Hard IP for Ethernet (10G/25G) will occasionally issue a TX timestamp that is 1 second larger than expected. This causes an inaccurate error of 1 second in the TX timestamp.
Resolution
A possible work around to this problem would be to compare the TX timestamp against the time-of-day(ToD), and then subtract 1 second from it if the timestamp is 1 second larger than the ToD.
This problem is scheduled to be fixed in the next release of the Intel® Quartus® Prime software.
Updated 3 months ago
Version 2.0
