Knowledge Base Article
Why is the input common mode voltage (VICM) of the Arria II GX dedicated transceiver refclk pins lower than the 1.1V device specification?
Description
Due to a problem in the Quartus® II software version 13.1 and earlier, the input common mode voltage (VICM) of the Arria® II GX dedicated transceiver refclk pins with on-chip termination (OCT) enabled is 0.82V instead of 1.1V.
A VICM of 0.82v on the dedicated REFCLK pins will not cause any problems when your signal is AC coupled.
Resolution
This issue will be fixed in a future version of the Quartus® II software.Updated 2 months ago
