Knowledge Base Article
Why is the dummy RX PHY required for reconfiguration missing from the Intel® FPGA SDI II IP generated Multi Rate Bidirectional mode design example?
Description
Due to a problem with the Intel® FPGA SDI II IP in Intel® Quartus® Prime Pro software version 17.1, you may observe that the dummy RX PHY required for reconfiguration is missing from the IP generated Multi Rate Bidirectional mode design example targetting Intel® Stratix® 10 devices. This problem affects Windows* OS configurations only.
Resolution
To work around this problem, generate the design example in Linux* OS.
This problem has been fixed starting in Intel Quartus Prime Pro software version 17.1.2.
Updated 3 months ago
Version 3.0No CommentsBe the first to comment
