Knowledge Base Article
Why is the Configuration Mode (AnF) bit set to 0 in the Remote Update FPGA IP when using Direct To Application (DTA) mode in Arria® 10 devices?
Description
When using Direct To Application (DTA) mode in Arria 10 devices, the Configuration Mode (AnF) bit in the Remote Update IP cannot be used as a mechanism to identify which configuration image is currently loaded.
Resolution
You can set the AnF bit once you configure your first Application image and transition to a subsequent application image.
Updated 2 months ago
