Knowledge Base Article
Why is the Clock Status Summary report missing in TimeQuest Unconstrained Paths report
Description
Due to a problem in the Quartus® II software version 12.0 and later, only the Unconstrained Paths Summary is generated when you select select Generate Report in TimeQuest... for Unconstrained Paths. The Clock Status Summary, the Setup Analysis and the Hold Analysis are missing.
Resolution
To work around this problem, run Report Unconstrained Paths task in the TimeQuest Timing Analyzer.
This problem is scheduled to be fixed in a future release of the Quartus II software.
Updated 3 months ago
