Knowledge Base Article
Why is the checksum value generated by the Quartus II software programmer different than the checksum value generated by the Tcl checksum command?
Description
The checksums generated by the Quartus® II software and the Tcl checksum command are different because they are calculated using different algorithms. The checksum generated by the Quartus II software is calculated using a simple summation of the bytes of the programming/configuration data. The Tcl checksum command uses a different method of calculation (CRC-32 or Adler32) and calculates the checksum on the entire file.
Related Articles
Updated 1 month ago
