Knowledge Base Article
Why is the Add PR Programming File Option disabled in Programmer?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software, you may see the Add PR Programming file option is disabled when doing Partial Reconfiguration (PR) over JTAG operation in Programmer as below:
  1. Open Programmer and click Auto Detect.
  2. Right-click FPGA and choose Change File, then choose .sof file and click OK.
  3. Right-click the .sof file, you will find the Add PR Programming File Option is disabled.
Resolution
To work around this problem, follow the steps below:
  1. Open Programmer and click Add File, then choose .sof file and click OK.
  2. Right-click .sof file, and you will find Add PR Programming File Option is enabled.
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 22.4.
Updated 27 days ago
Version 2.0
