Knowledge Base Article
Why is the 25G Ethernet Intel® FPGA IP oversized frame error not asserted when frame length setting is greater than 32k?
Description
Due to a problem in the Intel® Quartus® Prime Edition software version 18.1 and later, the 25G Ethernet Intel® FPGA IP core MAC frame length internal counter will overflow when frame length configuration register "MAX_TX_SIZE_CONFIG" and "MAX_RX_SIZE_CONFIG" is set to greater than 32k value.
Oversized frame error stays de-asserted as internal counter already overflow, hence not reflecting the actual error in hardware.
Resolution
This problem is fixed starting from the Intel® Quartus® Prime Pro Edition v20.3 software onwards.
The 25G Ethernet Intel® FPGA IP core MAC design fixed detail as below:
  • To handle frame length equal to MAX_TX_SIZE_CONFIG and MAX_RX_SIZE_CONFIG of 64k moving forwards.
  • Also if Ethernet packet frames with a size larger than 64k is received in the 25G Ethernet Intel® FPGA IP core, the MAC will detect the overflow condition and stops incrementing the internal frame length counter. Oversized frame error will also get asserted to indicate an overflow scenario.
Updated 3 months ago
Version 2.0
