Knowledge Base Article
Why is the -reorganize option for Tcl command export_assignments not recognized by Quartus II Tcl Console?
Description
Due to a problem in the Quartus® II software versions 10.0 and later, executing the command export_assignments with the option -reorganize is not recognized in the Quartus II Tcl Console.
To work around this problem, perform the following steps:
- From the Windows or Linux command prompt, open a Quartus II shell using the command
quartus_shor other Quartus II command-line executable. - Execute the command
export_assignments -reorganize.
This problem is fixed beginning with the Quartus II software version 11.0.
Updated 3 months ago
