Knowledge Base Article
Why is Quartus II programmer checksum different than general checksum calculations of the .pof or .jic?
Description
The Quartus® II programmer calculates the checksum using only the data which will be programmed to the configuration device. The programmer object file (.pof) or JTAG Indirect Configuration file (.jic) has additional file information which is not programmed into the configuration device, the checksum calculated from the entire .pof or .jic is therefore not identical to the one programmer displays.Updated 2 months ago
Version 3.0No CommentsBe the first to comment
