Knowledge Base Article
Why is not ping continuous and the packets are getting missed when using Triple Speed Ethernet Intel® FPGA IP with 10/100/1000 Mb Ethernet MAC with 1000BASE-X/SGMII PCS core variation?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.2, you might see ping is not continuous and the packets are getting missed when using Triple Speed Ethernet Intel® FPGA IP with 10/100/1000 Mb Ethernet MAC with 1000BASE-X/SGMII PCS core variation.
The cause of this problem is that 1000BASE-X transceiver truncates first byte of preamble and replaces it with IDLE byte due to the "EVEN" alignment in Clause 36.
Resolution
This problem is fixed beginning with the Intel® Quartus® Prime Pro Edition Software version 23.1.
Updated 2 months ago
