Knowledge Base Article
Why is no video output displayed when migrating the F-Tile SDI II FPGA IP Design Example with 12G multi-rate from an older version to Quartus® Prime Pro Edition Software version 25.3.1 patch 1.10 ?
Description
Due to an issue in the Quartus® Prime Pro Edition Software Programmer version 25.3.1, users may observe that no SDI II video output is displayed on the receiver side when using the F-tile SDI II FPGA IP Design Example with 12G multi-rate on Agilex® 7 FPGA devices.
This issue is caused by forcing lock-to-data. For SDI dynamic reconfiguration designs, manual CDR lock mode with lock-to-ref enabled should be used.
Resolution
To solve this problem, use below method
1. Open Platform Designer of sdi_rx_sys.qsys
2. Disable fgt_rx_set_locktodata port, Enable fgt_rx_set_locktoref port
3. At System View
    • Should not seeing fgt_rx_set_locktodata port
    • Export fgt_rx_set_locktoref port out
4. Sync info and regenerate HDL
5. Open rx_top.sv file
    • Comment out / remove fgt_rx_set_locktodata
    • Add exported fgt_rx_set_locktoref port and connect to ~rx_set_ltd
6. Save and recompile design
This problem is scheduled to be fixed in a future release of the Quartus Prime Pro Edition software.
Updated 8 months ago
Version 2.0
