Knowledge Base Article
Why is my USB Blaster II not detected by Quartus II on Windows?
Description
The USB-Blaster™ II  may not be detected if there is a conflict between the USB-Blaster II driver and other 3rd party drivers on your PC.
If your USB-Blaster II is not detected when running jtagconfig from the command line, you should inspect the Windows Device Manager.
If there is a conflict with a different USB driver:
  •  The Altera® USB-Blaster II (Unconfigured) device is shown with a warning symbol in the Windows Device Manager
  • The device status pane of the properties window for the Altera USB-Blaster II (Unconfigured) device displays (Code 38).
Resolution
To resolve this problem, the USB device that is in conflict with the USB-Blaster II should be unplugged.
Many computers also use USB to communicate with built-in peripherals such as SD card readers.  These devices may be disabled using the Windows Device Manager.
This problem is scheduled to be resolved in a future release of the Quartus® II software.
Updated 2 months ago
Version 2.0
