Knowledge Base Article
Why is my set_clock_groups command ignored during static timing analysis?
Description
Due to a problem in the Quartus® II software versions 11.1 SP2 and earlier, the set_clock_groups command may be ignored with no warning or error message if you use incorrect syntax by including a command that returns a group or collection within braces {}.
In the following example, the set_clock_groups command is ignored:
set_clock_groups -asynchronous -group {[get_clocks {clkA}]} -group {clkC}
Resolution
To avoid this behavior, use the correct syntax as shown below:
  • Remove the braces {} from around the command that returns a collection:
    set_clock_groups -asynchronous -group [get_clocks {clkA}] -group {clkC}
  • Replace the get_clocks command with a list:
    set_clock_groups -asynchronous -group {clkA} -group {clkC}
Updated 2 months ago
Version 2.0
