Knowledge Base Article
Why is my PCI Express core's tx_out always HiZ during simulation?
Description
When simulating your PCI Express® core you may observe that the PCI Express core appears to come out of reset properly and begin Link Initialization, but does not complete Link Initialization and the tx_out[n] port appears to be continuously in the HiZ state.
This may be the result of your testbench configuration, specifically the configuration of the test_in bus to speed up serial simulation.
Resolution
To workaround this issue, configure your testbench to speed up link initialization, by setting test_in[0] = 1.
For simulation, it is recommended that you set test_in[39:0] = 0x0AD or 0x0A9.
The meaning of these bits are as listed below:
[7] = Disable power management
[5] = Disable the core from entering Compliance Mode
[3] = FPGA mode
[2] = Disable scrambling
[0] = Speed up serial simulation
Related Articles
Updated 3 months ago
Version 2.0
