Knowledge Base Article
Why is my multi-dimensional port split into individual single-bit ports in the gate-level simulation netlist?
Description
Due to a limitation in the Quartus® II software, for designs written in AHDL with Verilog HDL specified as the output simulation netlist format, multi-dimensional ports are split into individual single-bit ports in the output netlist.Resolution
To work around this limitation, generate your output simulation netlist in VHDL instead of Verilog HDL.
Updated 3 months ago
