Knowledge Base Article
Why is my HPS DDR3 controller failing calibration?
Description
Your HPS DDR3 controller generated with Quartus® II software version 13.0 or 13.0sp1 may experience a calibration failure and produce the following debug messages in the debug output text file:
test_load_patterns(0,ALL) => (85 == 255) => 0
Guaranteed read test failed
SEQ.C: Calibration Failed
SEQ.C: Error Stage : 1
SEQ.C: Error Substage: 1
SEQ.C: Error Group : 0
There is a known issue where the HPS Vref pins draw high current causing the Vref voltage to drop and DDR3 calibration to fail.
Resolution
Install the Quartus® II 13.0SP1 release DP5 patch. See the link in Related Solutions below.
The same fix is also available as a separate patch (1.34) for the Quartus® II 13.0SP1 release. It is recommended that users install the DP5 patch, but should a separate patch for only the HPS Vref issue be required, please contact Altera.
This issue has been fixed in the Quartus® II software 13.1 release.
Related Articles
Updated 2 months ago
Version 3.0
