Knowledge Base Article
Why is my Fast Input Register, Fast Output Register or Fast Output Enable Register assignment ignored when enabling the SignalTap II Logic Analyzer in my design?
Description
When the SignalTap™ II Logic Analyzer is included in a design, register control signals may be promoted to global nets by the Quartus® II software. Registers with control signals on global nets cannot be packed into the I/O element. If a register with a Fast Input Register, Fast Output Register or Fast Output Enable Register assignment cannot be packed into the I/O element, the following warning message is generated:
Warning: Ignoring invalid fast I/O register assignments. See the Ignored Assignments panel in the Fitter Compilation Report for more information.
To work around this problem, prevent the control signal from being promoted to a global signal by following these steps:
  1. Open the Assignment Editor from the Assignments menu.
  2. Create a new assignment by clicking <<new>> on the Filter bar.
  3. Enter the name of the control signal by typing it in the To field or by double-clicking and using the Node Finder tool.
  4. Select Global Signal in the Assignment Name field.
  5. Select Off in the Value field.
Updated 2 months ago
Version 2.0
