Knowledge Base Article
Why is my Cyclone V or Stratix V Altera_PLL reset port is inverted in simulation?
Description
Due to a problem in the Quartus® II software version 13.1, you see the the Altera PLL reset port is inverted in gate level simulation. This problem occurs in Cyclone® V or Stratix® V designs when advanced mode or reconfiguration is enabled in the Altera_PLL.
Resolution
To work around this problem in ModelSim, add the following switch to the vlog command
define POSTFIT_SIM_USE_ICD_PLL_MODEL
For example add the following lines to the *_run_msim_gate_verilog.do file
For Cyclone V designs
vlog define POSTFIT_SIM_USE_ICD_PLL_MODEL <QuartusII_installation_path>/quartus/eda/sim_lib/mentor/cyclonev_*.v
vlog define POSTFIT_SIM_USE_ICD_PLL_MODEL <QuartusII_installation_path>/quartus/eda/sim_lib/cyclonev_atoms.v
For Stratix V designs
vlog define POSTFIT_SIM_USE_ICD_PLL_MODEL <QuartusII_installation_path>/quartus/eda/sim_lib/mentor/stratixv_*.v
vlog define POSTFIT_SIM_USE_ICD_PLL_MODEL <QuartusII_installation_path>/quartus/eda/sim_lib/stratixv_atoms.v
<QuartusII_installation_path>/quartus/eda/sim_lib/altera_primitives.v
vlog define POSTFIT_SIM_USE_ICD_PLL_MODEL <QuartusII_installation_path>/quartus/eda/sim_lib/altera_lnsim.sv
vlog define POSTFIT_SIM_USE_ICD_PLL_MODEL <QuartusII_installation_path>/quartus/eda/sim_lib/220model.v
vlog define POSTFIT_SIM_USE_ICD_PLL_MODEL <QuartusII_installation_path>/quartus/eda/sim_lib/sgate.v
vlog define POSTFIT_SIM_USE_ICD_PLL_MODEL <QuartusII_installation_path>/quartus/eda/sim_lib/altera_mf.v
vsim  -t 1ps transport_int_delays transport_path_delays -voptargs= acc gate_work.<top_level_design.vho/vo>
Related Articles
Updated 2 months ago
Version 2.0
