Knowledge Base Article
Why is my calculated value for rx_tam_adjust incorrect when using the scripts found in the design examples for multilane PTP variants of the F-tile Ethernet Intel® FPGA Hard IP?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.3, the ptp_fw.tcl” script provided in the design examples for multilane PTP variants of the F-tile Ethernet Intel® FPGA Hard IP might yield incorrect rx_tam_adjust values.
Resolution
To work around this problem, perform the following steps:
  1. Open the PTP firmware script located at <generated example design folder>/hardware_test_design/hwtest/altera/ptp/ptp_fw.tcl
  2. Find and replace the following lines of code:
FROMTO
# b) Calculate pulse adjustment
for {set fl 0} {$fl < $::FL} {incr fl} {
    set rx_xcvr_if_pulse_adj($fl) [format 0x%X $rx_fec_cw_pos_fl($fl)]
# b) Calculate pulse adjustment and check for FEC's cw_pos rollover between FEC lane received from the same transceiver lane
            set fl_minus [expr $fl - [expr $fl % $::PL_FL_MAP]]
            set cond1a [expr ($rx_fec_cw_pos_fl($fl) >= $rx_fec_cw_pos_fl($fl_minus))]
            set cond1b [expr (($rx_fec_cw_pos_fl($fl) - $rx_fec_cw_pos_fl($fl_minus)) > 0x4E20)]
            set cond2a [expr ($rx_fec_cw_pos_fl($fl_minus) > $rx_fec_cw_pos_fl($fl))]
            set cond2b [expr (($rx_fec_cw_pos_fl($fl_minus) - $rx_fec_cw_pos_fl($fl)) > 0x4E20)]
            if {$cond1a && $cond1b} {
                if {$::FEC == 2} {
                    # KRFEC
                    set rx_xcvr_if_pulse_adj($fl) [expr 0x5280 - $rx_fec_cw_pos_fl($fl)]
                } elseif {($::FEC == 3) || ($::FEC == 4)} {
                    # KP/LLFEC
                    set rx_xcvr_if_pulse_adj($fl) [expr 0x5500 - $rx_fec_cw_pos_fl($fl)]
                set rx_xcvr_if_pulse_adj_sign($fl) 0x1
            } elseif {$cond2a && $cond2b} {
                if {$::FEC == 2} {
                    # KRFEC
                    set rx_xcvr_if_pulse_adj($fl) [expr 0x5280 + $rx_fec_cw_pos_fl($fl)]
                    # KP/LLFEC
                    set rx_xcvr_if_pulse_adj($fl) [expr 0x5500 + $rx_fec_cw_pos_fl($fl)]
                set rx_xcvr_if_pulse_adj_sign($fl) 0x0
            } else {
return [array get rx_xcvr_if_pulse_adj]
set l_rx_xcvr_if_pulse_adj [array get rx_xcvr_if_pulse_adj]
set l_rx_xcvr_if_pulse_adj_sign [array get rx_xcvr_if_pulse_adj_sign]
return [list $l_rx_xcvr_if_pulse_adj $l_rx_xcvr_if_pulse_adj_sign]
proc determine_rx_ref_lane {lst_rx_xcvr_if_pulse_adj VL ui rx_pcs_bitslip_cnt rx_pcs_dlpulse_aligned l_rx_apulse_offset l_rx_apulse_offset_sign l_rx_apulse_wdelay l_rx_apulse_time ip_inst_base_addr} {
    # arguments:
    # returns: 'array-lists' for rx spulse offset (+sign bit). rx ref pl/vl/fl
    array set rx_apulse_offset      $l_rx_apulse_offset
    array set rx_apulse_offset_sign $l_rx_apulse_offset_sign
    array set rx_apulse_wdelay      $l_rx_apulse_wdelay
    array set rx_apulse_time        $l_rx_apulse_time
    array set rx_xcvr_if_pulse_adj  $lst_rx_xcvr_if_pulse_adj
    print_info_time "Determine RX reference lane"
    # a) Determine sync pulse (Alignment Marker) offsets with reference to async pulse
    if {$::FEC > 0} {
        print_out "\tVariant                    : FEC>0"
            set val0 [format 0x%X [expr $rx_xcvr_if_pulse_adj($fl_minus) & 0x0000001F]]
            set val1 [format 0x%X [expr $rx_xcvr_if_pulse_adj($fl) + $val0]]
            if {$val1 > $rx_xcvr_if_pulse_adj($fl_minus)} {
                set rx_spulse_offset_sign($fl) 0
                set rx_spulse_offset_0      [format 0x%lX [expr [expr ($rx_xcvr_if_pulse_adj($fl) - $rx_xcvr_if_pulse_adj($fl_minus)) + $val0] * $ui * $::PL_FL_MAP]]
                set rx_spulse_offset_1      [format 0x%lX [expr $rx_spulse_offset_0 & 0x7FFFFFFFFFF]] ; # 43'rx_spulse_offset_0
                set rx_spulse_offset($fl)   [format 0x%X [expr $rx_spulse_offset_1 >> [expr 28 - 16]]]
            } else {
                set rx_spulse_offset_sign($fl) 1
                set rx_spulse_offset_0      [format 0x%lX [expr [expr ($rx_xcvr_if_pulse_adj($fl_minus) - $rx_xcvr_if_pulse_adj($fl)) - $val0] * $ui * $::PL_FL_MAP]]
proc determine_rx_ref_lane {lst_rx_xcvr_if_pulse_adj lst_rx_xcvr_if_pulse_adj_sign VL ui rx_pcs_bitslip_cnt rx_pcs_dlpulse_aligned l_rx_apulse_offset l_rx_apulse_offset_sign l_rx_apulse_wdelay l_rx_apulse_time ip_inst_base_addr} {
    # arguments:
    array set rx_xcvr_if_pulse_adj_sign  $lst_rx_xcvr_if_pulse_adj_sign
    if {$::FEC > 0} {
            if {$rx_xcvr_if_pulse_adj_sign($fl) == 1} {
                set rx_spulse_offset_0      [format 0x%lX [expr $rx_xcvr_if_pulse_adj($fl) * $ui * $::PL_FL_MAP]]
            } else {
            } else {
array set rx_xcvr_if_pulse_adj [configure_rx_fec_cw_pos $inst_num $init_pl]
if {$::FEC > 0} {
    set int_list [configure_rx_fec_cw_pos $inst_num $init_pl]
    lassign $int_list l_rx_xcvr_if_pulse_adj l_rx_xcvr_if_pulse_adj_sign
    array set rx_xcvr_if_pulse_adj $l_rx_xcvr_if_pulse_adj
    array set rx_xcvr_if_pulse_adj_sign $l_rx_xcvr_if_pulse_adj_sign
    if {$::debug} {
            print_out "\trx_xcvr_if_pulse_adj($fl)        : [format 0x%08X $rx_xcvr_if_pulse_adj($fl)]"
            print_out "\trx_xcvr_if_pulse_adj_sign($fl)   : [format 0x%08X $rx_xcvr_if_pulse_adj_sign($fl)]"
# Step 3: Determine RX reference lane
set int_list [determine_rx_ref_lane [array get rx_xcvr_if_pulse_adj]\
                $VL\
                [array get rx_xcvr_if_pulse_adj_sign]\
                $VL
  1. Save the file
This problem is fixed beginning with the Intel® Quartus® Prime Pro Edition Software version 22.4.
Updated 18 days ago
Version 2.0
