Knowledge Base Article
Why is flashsm_reset reported as an unconstrained clock in the PFL IP?
Description
Due to a limitation in the Intel® Quartus® Prime software, you may see flashsm_reset reported as an unconstrained clock. This occurs when you instantiate the Parallel Flash Loader (PFL) IP in an Intel® MAX® 10 device.
Resolution
flashsm_reset is not a clock, so it is safe to ignore this warning.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
