Knowledge Base Article
Why is an unexpected functional failure observed on Arria 10 devices when performing fault injection with the Fault Injection Debugger IP?
Description
Due to an issue in Quartus® Prime software versions earlier than 17.0, the Fault Injection Debugger IP may cause CRAM corruption during fault injection in Arria® 10 devices, which may lead to one of the following failures :
- Fault Injection IP not found.
- Lost SignalTap instance.
- Failure to read the Error Message Register (EMR) or read invalid EMR content.
- Internal Scrubbing cannot recover the functional failure in user logic.
Resolution
This issue is resolved in Quartus® Prime software version 17.0.
Updated 2 months ago
