Knowledge Base Article
Why is an unconstrained clock error reported when using the Error Message Register Unloader Intel® FPGA IP?
Description
Due to a problem in the Intel® Quartus® Prime Standard Edition Software version 20.1 and later,  an unconstrained clock is reported in the check timing report in the Timing Analyzer as shown below when using the Error Message Register Unloader Intel® FPGA IP. This problem occurs on Cyclone® V FPGAs.
emr_unloader_component|current_state.STATE_CLOCKHIGH ; Node was determined to feed a clock port but was found without an associated clock assignment.
emr_unloader_component|crcblock_atom:emr_atom|generate_crcblock_atom.emr_atom~FF_** ; No clock feeds this register's clock port.
Resolution
To work around this problem, add the create_generated_clock  constraint to your SDC file.
For example:
create_generated_clock -name emr_unloader_STATE_CLOCKHIGH -source [get_ports {<clock name>}] [get_keepers {<path to IP>|EMR_unloader0:inst|EMR_unloader0_emr_unloader2_0:emr_unloader2_0|altera_emr_unloader:emr_unloader_component|current_state.STATE_CLOCKHIGH}]
Updated 3 months ago
Version 2.0
