Knowledge Base Article
Why is an error message shown when generating the F-Tile Ethernet Intel® FPGA Hard IP Multi-instance IP core example design enabled with the SyncE feature?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.3, you might see an error message in the System Messages tab of the IP Catalog when both the following conditions are met:
- Enable dedicated CDR clock output option in the IP tab is checked to enable SyncE feature.
- Multi instance of IP core menu is selected in the Example Design tab
Resolution
To work around this problem, you can generate a separate "Single Instances of IP core" enabled with SyncE feature and stitch them together for multi instances manually.
For example, you can refer to the diagram "Clock Connection of Sync-E clock through CDR clock out pin" described in the F-Tile Ethernet Intel® FPGA Hard IP User Guide.
This problem is fixed beginning with the Intel® Quartus® Prime Pro Edition Software version 22.4.
Updated 3 months ago
Version 3.0No CommentsBe the first to comment
