Knowledge Base Article
Why is afi_rlat tied to ground in my UniPHY-based PHY-Only instance of the external memory interface?
Description
The use of the afi_rlat signal is not supported for PHY-Only designs.
Resolution
The workaround is to use the afi_rdata_valid signal to determine when valid read data is available.
For more information, refer to the External Memory Interface Handbook.
Updated 2 months ago
Version 2.0
