Knowledge Base Article
Why is a link-up error seen in simulation using the F-Tile Ethernet FPGA Hard IP when used in the MACsec FPGA IP System Example Design?
Description
Due to a problem in the Quartus® Prime Pro Edition Software versions 24.1 and 24.2, the F-Tile Ethernet FPGA Hard IP shows a link-up error, causing the transmitter reset to acknowledge and transmitter lanes stability to fail.
This problem is seen in designs that are custom made as in the MACsec FPGA IP System Example Design.
Resolution
This problem is fixed beginning with the Quartus® Prime Pro Edition software version 24.3.
Updated 11 months ago
Version 3.0
