Knowledge Base Article
Why I can’t see /sys/class/fpga-bridge/lwhps2fpag folder with my Linux in a A10 SoC kit?
Description
You can run below commands to enable or disable bridges which are available in your SoC platform.
echo 1 > /sys/class/fpga-bridge/fpga2hps/enable
echo 1 > /sys/class/fpga-bridge/hps2fpga/enable
echo 1 > /sys/class/fpga-bridge/lwhps2fpga/enable
If you failed to find those folders, please check the DTS you are using to make sure below nodes are available:
fpgabridge0: fpgabridge@0 {
                     compatible = "altr,socfpga-hps2fpga-bridge";    /* appended from boardinfo */
                     label = "hps2fpga"; /* appended from boardinfo */
                     reset-names = "hps2fpga";  /* appended from boardinfo */
                     clocks = <&l4_main_clk>;    /* appended from boardinfo */
                     resets = <&hps_0_rstmgr 96>;    /* appended from boardinfo */
              }; //end fpgabridge@0 (fpgabridge0)
              fpgabridge1: fpgabridge@1 {
                     compatible = "altr,socfpga-lwhps2fpga-bridge"; /* appended from boardinfo */
                     label = "lwhps2fpga";    /* appended from boardinfo */
                     reset-names = "lwhps2fpga";      /* appended from boardinfo */
                     resets = <&hps_0_rstmgr 97>;    /* appended from boardinfo */
              }; //end fpgabridge@1 (fpgabridge1)
              fpgabridge2: fpgabridge@2 {
                     compatible = "altr,socfpga-fpga2hps-bridge";    /* appended from boardinfo */
                     label = "fpga2hps"; /* appended from boardinfo */
                     reset-names = "fpga2hps";  /* appended from boardinfo */
                     resets = <&hps_0_rstmgr 98>;    /* appended from boardinfo */
              }; //end fpgabridge@2 (fpgabridge2)
              fpgabridge3: fpgabridge@3 {
                     compatible = "altr,socfpga-fpga2sdram-bridge"; /* appended from boardinfo */
                     label = "fpga2sdram";   /* appended from boardinfo */
                     read-ports-mask = <0x0000000f>;      /* appended from boardinfo */
                     write-ports-mask = <0x0000000f>;     /* appended from boardinfo */
                     cmd-ports-mask = <0x00000001>;     /* appended from boardinfo */
              }; //end fpgabridge@3 (fpgabridge3)
Updated 3 months ago
Version 2.0
