Knowledge Base Article
Why I am not able to send OPCODE command using Intel® Stratix® 10 Serial Flash Mailbox Client IP?
Description
When you are trying to send OPCODE command using Intel® Stratix® 10 Serial Flash Mailbox Client IP, you will observe that the command is not being sent to the flash correctly.
The reason is that there is a document error on the user guide where the offset 13 (CONTROL) register of the CSR for bit [5:3] is incorrect.
The correct bit is [6:4]
Resolution
To performed read data OPCODE, you will need to set 0x4 to bit [6:4].
To performed write data OPCODE, you will need to set 0x2 to bit [6:4].
This information will be updated in the document future release.
Updated 3 months ago
Version 3.0No CommentsBe the first to comment
