Knowledge Base Article
Why HPS booting from QSPI will hang after we configure the HPS cold reset register on CV SoC dev kit?
Description
Due to advanced and high density serial flash devices that can operate in modes(three-byte/four-byte addressing mode)more capable than the common configuration that is assumed by three-byte addressing mode, the Intel® Cyclone ® V HPS will hang when configure the HPS cold reset register(0xffd05004) through the UBOOT command “mw 0xffd05004 0x00110001” without resetting QSPI flash to three-byte addressing mode. The UART print as below:
CPU: Altera SOCFPGA Platform
BOARD: Altera SOCFPGA Cyclone V Board
I2C: ready
DRAM: 1GiB
MMC: ALTERA DWMMC: 0
SF: Read data capture delay calibrated to 3 (0- 7)
SF: Detected N25Q512 with page size 65536, total: 67108864
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: mii0
Hit any key to stop autoboot: 0
SOCFPGA_CYCLONE5 #
SOCFPGA_CYCLONE5 # mw 0xffd05004 0x00110001
Resolution
You can set the QSPI in three-byte address mode before configuring the HPS cold reset register(0xffd05004) or output the h2f_cold_reset from FPGA pin to reset the QSPI Flash to three-byte address mode.
