Knowledge Base Article
Why Generic Serial Flash Interface FPGA IP write Micron QSPI flash memory incorrectly when using HAL APIs?
Description
This problem might be seen in the Quartus® Prime Pro Edition Software version 22.1 when writing Micron QSPI flash memory using the HAL APIs of the Generic Serial Flash Interface FPGA IP (GSFI IP).
The HAL API for the GSFI IP is available in the following software files:
• intel_generic_serial_flash_interface_top.h
• intel_generic_serial_flash_interface_top.c
This is due to an inappropriate polling opcode in the intel_gsfi_write_block() API for the Micron QSPI flash device. Other supported flashes are not affected by this.
Resolution
To work around this, follow these steps:
  1. Locate the drivers/src folder in your Board Support Package (BSP) project.
  2. Search for the intel_generic_serial_flash_interface_top.c software file.
  3. Search for the intel_gsfi_write_block()API.
  4. Modify the API from CMD_STATUS_REGISTER to CMD_FLAG_STATUS_REGISTER.
Example:
Line 1244 : cmd = ((CMD_FLAG_STATUS_REGISTER << 8) | CMD_QUAD_INPUT_FAST_PROGRAM);
Line 1255 : cmd = ((CMD_FLAG_STATUS_REGISTER << 8) | CMD_PAGE_PROGRAM);
Note: Regenerating the BSP resets the HAL APIs to their original state.
This problem is currently scheduled to be resolved in a future release of the Quartus® Prime Software.
Updated 2 months ago
Version 2.0
