Knowledge Base Article
Why error is found when generating HDMI RX PHY IP or HDMI TX PHY IP Design Example?
Description
Due to the migration of the Nios® II Processor for FPGA to the Nios® V Processor for FPGA, the following error will appear when generating the Design Example from the HDMI RX PHY IP or the HDMI TX PHY IP in the Quartus® Prime Pro Edition Software version 24.1
Resolution
There is no workaround for this problem.
This problem is fixed beginning with version 25.1.1 of the Quartus® Prime Pro Edition Software.
Updated 2 months ago
