Knowledge Base Article
Why don't the IOPLL output clocks operate as expected when using Advanced Mode reconfiguration following table 18 in the Intel Agilex® 7 FPGA Clocking and PLL User Guide?
Description
Due to a problem in the Intel Agilex® 7 FPGA Clocking and PLL User Guide (UG-20216) version 2021.06.21, the address map for C1-C7 counters in table 18 is incorrect.
Therefore, if you follow the address map in table 18, the IOPLL output clocks will not output the correct clocks as expected.
Resolution
To work around this problem, follow the address setting and C Counter Mapping as shown in the following table.
Output Clock
C Counter
High Count
Low Count
Bypass Enable
Odd Divison
outclock0
C1
00011111
00100010
00100000
00100001
outclock1
C2
00100011
00100110
00100100
00100101
outclock2
C3
00100111
00101010
00101000
00101001
outclock3
C4
00101011
00101110
00101100
00101101
outclock4
C5
00101111
00110010
00110000
00110001
outclock5
C6
00110011
00110110
00110100
00110101
outclock6
C7
00110111
00111010
00111000
00111001
This problem is fixed starting with the release of the Intel Agilex® 7 FPGA Clocking and PLL User Guide version 2022.11.09.
Updated 1 month ago
Version 2.0
