Knowledge Base Article
Why don't some IP components show up in the IP Catalog?
Description
If you set '_JAVA_OPTIONS' environment variable on your Windows operating system, some IPs may not show up in the IP Catalog.
Resolution
To work around this limitation, delete the Windows environment variable \'_JAVA_OPTIONS\'. To delete the variable, follow instructions below.
  1.  Open the Control Panel
  2.  Go to System and Security
  3.  Go to System
  4.  Go to Advanced System Properties
  5.  Click Environment Variables
  6.  Select variable name _JAVA_OPTIONS
  7.  Click Delete button
Updated 2 months ago
Version 2.0
