Knowledge Base Article
Why doesn't the watchdog timer increment even after starting it?
Description
There is an issue with Qsys in the Quartus® II software versions 11.x when configuring the interval timer as a watchdog. The chip select signal is not connected. This will be fixed in a later version of the Quartus II software.
As a workaround, edit the top level verilog file that Qsys generates. Search for the watchdog component. Tie off the chip select input signal to the interval timer to a 1'b1.
 timer_sys_timer_0 timer_0 (
  .clk          (clk_clk),                         // clk
  .reset_n      (~rst_controller_reset_out_reset), // reset_n
  .address      (timer_0_s1_agent_m0_address),     // address
  .writedata    (timer_0_s1_agent_m0_writedata),   // writedata
  .readdata     (timer_0_s1_agent_m0_readdata),    // readdata
  .chipselect   (1'b1),                            // chipselect
  .write_n      (~timer_0_s1_agent_m0_write),      // write_n
  .resetrequest (),                                // resetrequest
  .irq          (timer_0_irq_irq)                  // irq
Updated 2 months ago
Version 2.0
