Knowledge Base Article
Why doesn't the Quartus II software correctly synthesize signed packed array variables in SystemVerilog?
Description
Due to a problem in the Quartus® II software, signed packed array variables in SystemVerilog may not be synthesized correctly. This problem may occur when assigning a one-dimensional array variable to a signed packed array variable if the index range is not explicitly specified.
For example, the following code may be synthesized incorrectly by the Quartus II software:
logic clk;
logic signed [3:0][31:0] packed_array_variable;
logic signed [31:0] array_variable;
always_ff @ (posedge clk)
packed_array_variable[0] <= array_variable;Resolution
To work around this problem, explicitly declare the index range when assigning a one-dimensional array variable to a packed array variable.
For example, in the above code, change the last line to:
packed_array_variable[0][31:0] <= array_variable;Updated 11 months ago
Version 3.0No CommentsBe the first to comment
