Knowledge Base Article
Why doesn't the lock-to-reference (LTR) mode work for F-Tile PMA/FEC Direct PHY Intel® FPGA IP?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 23.1 and earlier, the lock-to-reference (LTR) mode can not be enabled for F-Tile PMA/FEC Direct PHY Intel® FPGA IP.
Resolution
There is no workaround for PMA type FGT with PAM4 and PMA type FHT with PAM4/NRZ.
However, there is a workaround for physical medium attachment (PMA) type FGT with nonreturn-to-zero (NRZ) to avoid this problem in the Intel® Quartus® Prime Pro Edition Software version 23.1 and earlier.
The following steps are an example of a signal-lane design:
  1. Add the following QSF assignments in the project .qsf file:
  • set_instance_assignment -name HSSI_PARAMETER "flux_mode=FLUX_MODE_BYPASS" -to rx_serial_data[0] -entity top
  • set_instance_assignment -name HSSI_PARAMETER "flux_mode=FLUX_MODE_BYPASS" -to tx_serial_data[0] -entity top
  • set_instance_assignment -name HSSI_PARAMETER "engineered_link_mode=ENABLE" -to rx_serial_data[0] -entity top
  • set_instance_assignment -name HSSI_PARAMETER "engineered_link_mode=ENABLE" -to tx_serial_data[0] -entity top
  • set_instance_assignment -name HSSI_PARAMETER "rx_adapt_mode=RX_ADAPT_MODE_STATIC_EQ" -to rx_serial_data[0] -entity top
             Note: Replace "rx_serial_data[0]" with the receiver signal of your design.
                        Replace "tx_serial_data[0]" with the transmitter signal of your design.
                        Replace "top" with the top-level entity name of your design.
            For a multi-lane design, you should have the above 5 assignments for every lane.
        2. Recompile and program your design.
        3. Through the Datapath Avalon® Memory-Mapped Interface, write CSR rx_ignore_locked2data register 0x818[0] with value 1'b1
        4. Assert rx_reset
        5. Through the PMA Avalon Memory-Mapped Interface, write the following registers with value 1'b1:
  • 0x41680[28]
  • 0x41680[24]
  • 0x41580[31]
  • 0x41580[30]
         6. De-assert rx_reset
This problem will be fixed in a future release of the Intel® Quartus® Prime Pro Edition Software.
Updated 3 months ago
Version 2.0
