Knowledge Base Article
Why doesn't the FPGA pull the nSTATUS pin low when an error occurs during configuration?
Description
The FPGA normally pulls the nSTATUS pin low when an error occurs during configuration. At the beginning of configuration, the FPGA needs to receive a preamble pattern in the configuration data (the preamble pattern for a configuration file is included automatically when the Quartus® II software generates the configuration file). If the FPGA does not receive this preamble pattern correctly, the FPGA will not be able to recognize a configuration error even after the entire configuration data has been sent to the FPGA. This results in the nSTATUS signal remaining high and the CONF_DONE signal remaining low.
If you see this symptom, check your setup to ensure that the FPGA is able to receive the configuration data correctly based on your programming files.
Updated 2 months ago
Version 2.0
