Knowledge Base Article
Why doesn't Rx_data_ready bit update when synchronization is lost?
Description
In the 10GBASE-R PHY IP core version 10.1 and earlier, the RX_DATA_READY which is bit 7 of the PCS status register (0x82) does not deassert when synchronization is lost.
Affected Configurations
This issue affects both Stratix® IV and Stratix V implementations of the 10GBASE-R PHY.
Solution Status
This issue is fixed in the 10GBASE-R PHY IP core version 11.0.
Resolution
The workaround is to monitor the internal signals that indicate lock status and perform a digital reset of the channel when synchronization is lost.
Updated 1 month ago
