Knowledge Base Article
Why doesn't my shift register get inferred when targeting Intel® Stratix®10 FPGA or Intel Agilex® 7 devices?
Description
Due to the Intel® Hyperflex™ FPGA architecture in the Intel® Stratix® 10 FPGA and Intel Agilex® 7 series devices, the threshold for shift register inference is increased, meaning that RTL-based shift registers which may have been inferred as shift registers in previous technologies may not be inferred in Intel Stratix® 10 FPGA and Intel Agilex® 7 series devices.
The reason for this threshold increase is to allow more registers to be retimed as hyper registers, which improves design performance.
Resolution
Intel® Stratix® 10 FPGA and Intel Agilex® 7 device series shift register inference criteria:
Default requirement:
The shift register must contain at least 69 registers in total (depth * width)
-Note that an additional inference stage takes place after the early retimer stage to recover area for registers that have not been retimed into Hyper register locations.
With the following assignment in place, the total number of required registers (depth * width) drops to 37:
set_global_assignment -name ALLOW_ANY_SHIFT_REGISTER_SIZE_FOR_RECOGNITION ON
With both of the following assignments in place, the total number of required registers (depth * width) drops to 13:
set_global_assignment -name PHYSICAL_SHIFT_REGISTER_INFERENCE=OFF
-Note that reducing the shift register inference threshold can negatively impact design performance by reducing the number of registers available for Hyper Retiming.
Updated 2 months ago
Version 2.0
