Knowledge Base Article
Why doesn't byteenable signal toggle between the two access addresses when a 32bit Avalon-MM Slave component is used to read over the PCIe 64bit Avalon Master in SOPC Builder?
Description
Due to a bug in SOPC Builder, the byteenable doesn't change between the two read transaction when
the PCIe® master has a wider bus width than the slaves (i.e. 32/16/8 bits Avalon Slave).
This problem exists in Quartus® II software design using SOPC Builder.
To work around this problem, you can add an Avalon®-MM Pipeline Bridge between PCIe Master and the slave.
This problem is fixed in Qsys.
Updated 3 months ago
