Knowledge Base Article
Why doesn’t the traffic stimuli send any traffic to the calibration IP when using the Intel Agilex® 7 FPGA PHYLite simulation design example with dynamic reconfiguration enabled?
Description
The Intel Agilex® 7 FPGA PHYLite simulation example design with dynamic reconfiguration enabled should show an example of dynamic reconfiguration working by changing the interpolator delay via the traffic stimuli. However, due to a problem in the Intel® Quartus® Prime Pro Edition Software version 20.4, the traffic stimuli in the Intel Agilex® 7 FPGA PHYLite simulation example design does not send any traffic to the calibration IP if the PHYLite group is set to Input pin type because the interpolator phase is set to a hardcoded value.
Note: This problem does not occur if the PHYLite group is set to Output pin type or Bidirectional pin type.
Resolution
To work around this problem in the Intel® Quartus® Prime Pro Edition Software version 20.4, the interpolator phase must not be a hardcoded value, which requires making some modifications to the phylite_tester.sv and test_logic_iossm.sv files to allow the traffic stimuli to read the interpolator phase, increment the read value, then modify the interpolator phase to the new value.
Perform the following changes to the file named “phylite_tester.sv”:
1.     Line #159: Remove state declaration PHASE DELAY and add two states declaration: CORE_PHASE_DELAY and IO_PHASE_DELAY
2.     Line #177: Change from
            assign iossm_test_start = (prbs_fsm == PHASE_DELAY);
        to
            assign iossm_test_start = (prbs_fsm == CORE_PHASE_DELAY);
3.     Line #323: Change the prbs_fsm signal in INIT state from
            prbs_fsm <= (CHANNEL_PIN_TYPE == "INPUT") ? IO_DRIVE : ((IOSSM_TEST_EN == 1) ? PHASE_DELAY : CORE_DRIVE);
        to
            prbs_fsm <= (IOSSM_TEST_EN == 1) ? (CHANNEL_PIN_TYPE == "INPUT" ? IO_PHASE_DELAY : CORE_PHASE_DELAY) : (CHANNEL_PIN_TYPE == "INPUT" ? IO_DRIVE : CORE_DRIVE);
4.     Line #338: Change the prbs_fsm signal in IO_CHECK state from
            prbs_fsm <= (CHANNEL_PIN_TYPE == "OUTPUT") ? ((IOSSM_TEST_EN == 1) ? PHASE_DELAY : CORE_DRIVE) : IO_DRIVE;
        to
            prbs_fsm <= (IOSSM_TEST_EN == 1) ? (CHANNEL_PIN_TYPE == "OUTPUT" ? CORE_PHASE_DELAY : IO_PHASE_DELAY) : (CHANNEL_PIN_TYPE == "OUTPUT" ? CORE_DRIVE : IO_DRIVE);
5.     Line #338: Change the prbs_fsm signal in CORE_CHECK state from
        to
6.     Line #341: Remove
            PHASE_DELAY: begin
                if (core_checker_failed | io_checker_failed)
                    prbs_fsm <= CHECKER_FAILED;
                else if (iossm_phase_shift_done)
                    prbs_fsm <= CORE_DRIVE;
               end
        and replace with these two:
            IO_PHASE_DELAY: begin
                   prbs_fsm <= IO_DRIVE;
           end
        CORE_PHASE_DELAY: begin
       end
Perform following changes to file named “test_logic_iossm.sv”:
1.     Line #43: Change the value of IOSSM_INIT_PIN_DELAY  to 196
2.     After line #45: Add local parameter declaration:
            localparam WAIT_INTERVAL = 8;
3.     Line #59: Add these three following states declaration after IOSSM_WAIT_REQ
           IOSSM_PRE_READ,
           IOSSM_PRE_RDATA,
           IOSSM_PRE_WAIT,
4.      Line #72: Change from
            if (!reset_n) begin
               pin_dly_write       <= IOSSM_INIT_PIN_DELAY;
               prev_pin_dly_write  <= IOSSM_INIT_PIN_DELAY;
           end else if (cal_debug_write && !cal_debug_waitrequest)begin
               prev_pin_dly_write  <= pin_dly_write;
               pin_dly_write       <= pin_dly_write IOSSM_DELAY_STEP;
            end
        to
           if (!reset_n) begin
               pin_dly_write       <= 0;
               prev_pin_dly_write  <= 0;
           end else if (cal_debug_read_data_valid && iossm_fsm == IOSSM_PRE_RDATA) begin
               prev_pin_dly_write  <= cal_debug_read_data[IOSSM_PIN_DELAY_WIDTH-1:0] IOSSM_DELAY_STEP;
            end
5.      Line #85: Change from
            end else if (cal_debug_read_data_valid) begin
        to
            end else if (cal_debug_read_data_valid && iossm_fsm == IOSSM_RDATA) begin
6.      Line #108: Change iossm_fsm signal in IOSSM_INIT state from
            iossm_fsm <= IOSSM_WRITE;
        to
             iossm_fsm <= IOSSM_PRE_READ;
7.      After IOSSM_INIT state, add these two following states:
            IOSSM_PRE_READ: begin
                if (!cal_debug_waitrequest)
                    iossm_fsm <= IOSSM_PRE_RDATA;
              end
            IOSSM_PRE_RDATA: begin
            end
8.      Line #139: Change from
            assign cal_debug_read  = iossm_fsm == IOSSM_READ;
        to
            assign cal_debug_read  = (iossm_fsm == IOSSM_READ) || (iossm_fsm == IOSSM_PRE_READ);
9.      Line #146: Change from
            assign wait_done = (req_wait_interval == 7) ? 1 : 0;
        to
            assign wait_done = (req_wait_interval == WAIT_INTERVAL-1) ? 1 : 0;
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 21.1.
Updated 3 months ago
Version 2.0
