Knowledge Base Article
Why doesn’t the CDR lock signal assert in simulation for some F Tile Ethernet Hard IP variants when using Questa*–Altera® FPGA Edition in the Quartus® Prime Pro Edition software version 25.3.1?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 25.3.1, you may see simulation failure that CDR lock signal doesn’t assert for some F‑Tile Ethernet Hard IP variants when using Questa*–Altera® FPGA Edition.
Resolution
There is no workaround currently.
The problem has been fixed starting with Quartus® Prime Pro Edition software version 26.1.
Updated 3 months ago
Version 5.0No CommentsBe the first to comment
