Knowledge Base Article
Why doesn’t ss_cold_rst_ack_n assert within 1ms of asserting ss_cold_rst_n for a mix of AN/LT and non-AN/LT configurations in the Ethernet Subsystem FPGA IP, F-Tile variant simulation with the Quartus® Prime Pro Edition Software version 24.1?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.1, for configurations involving a mix of ANLT and non-ANLT topology (for example Port0 - 100G_4 (AN = 1), Port4 - 10G_1 (AN = 0), Port5 - 25G_1 (AN = 1), etc.), when ss_cold_rst_n is asserted, ss_cold_rst_ack_n does not assert even after 1ms in the Ethernet Subsystem FPGA IP simulation. This occurs despite the INTC_SIM_AN_LT_ENABLE switch being defined, as the firmware version (fw_version) is not properly loaded.
Resolution
There is no workaround currently, and there is no plan to fix this problem.
Updated 5 months ago
Version 4.0No CommentsBe the first to comment
