Knowledge Base Article
Why does Timing Analyzer report negative-edge clocks as positive-edge clocks?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.2 and earlier, you may see negative-edge clocks being reported as positive-edge clocks by Timing Analyzer for registers in IO Cells. This problem only affects designs targetting Intel Agilex® devices.
Resolution
To work around this problem, manually disable register packing on any FF that has an inverted clock in an IO Cell. For example:
set_instance_assignment -name FAST_INPUT_REGISTER -to <to> -entity <entity name> OFF
set_instance_assignment -name FAST_OUTPUT_ENABLE_REGISTER -to <to> -entity <entity name> OFF
set_instance_assignment -name FAST_OUTPUT_REGISTER -to <to> -entity <entity name> OFF
This problem is fixed beginning with the Intel® Quartus® Prime Pro Edition software version 22.3.
Updated 20 days ago
Version 2.0
