Knowledge Base Article
Why does TimeQuest Timing Analyzer in Quartus II software versions 7.1 SP1 and beyond report several of the reset and serial loopback ports on high speed transceivers on Stratix II GX devices as unconstrained paths in red?
Description
Quartus® II software versions 7.1SP1 and beyond do not constraint the following reset and serial loopback ports on the ALTGX/ALT2GXB high speed transceivers, hence reporting the unconstrained paths.
  • gxb_powerdown
  • tx_digitalreset
  • rx_digitalreset
  • rx_analogreset
  • rx_seriallpbken
Resolution
Manually add the constraints in the Synopsys Design Constraints (.sdc) file for TimeQuest to analyze these paths. Instructions to manually add the constraints to the .sdc file are available in the Stratix II GX Device Handbook (PDF).
Updated 2 months ago
Version 3.0
