Knowledge Base Article
Why does the Viterbi Megacore generate an incorrect rr bus width?
Description
Due to a problem in the Viterbi Megacore® version 16.0 and earlier, the rr bus width calculation is always equal to n*softbit, therefore the rr bus width is incorrect when you select TCM mode.Resolution
To workaround this issue:
1. Open the altera_vit_ii_parameters.tcl file from the following directory
<Installation path>\ip\altera\dsp\altera_vit_ii\src\tcl_libs
2. Comment out line 414, and then add the following script
if { == "T" } {
set_parameter_value rr_size [expr **2]
} else {
set_parameter_value rr_size [expr *]
3. Re-open Quartus® and Re-generate the MegaCore
This problem is scheduled to be fixed in a future release of the Quartus Prime software.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
