Knowledge Base Article
Why does the VIP suite design fail to create a BSP project when using Nios II Eclipse?
Description
You will receive the following errors when creating a BSP project using Nios ® II Eclipse with Quartus® II software version 14.0.
1. “Failed to execute: ./ create-this-bsp –cpu-name cpu –no-make” 2. SEVERE: File not found "C:\altera\14.0\ip\altera\”Name of MegaCore”\..\..\component_sw\ Name of MegaCore.hpp” This problem will occur if your design contains any of the following MegaCore® functions:1. Frame Reader
2. Clock video input
3. Clock video output
4. Control synchronizer
5. Switch
Resolution
To work around this problem, please remove the following 5 plugin sections in the file "<quartus_install_path>/ip/altera/altera_components.ipx", and then refresh and regenerate the Qsys® system.
- <plugin
name="cti_driver"
file="clocked_video_input/alt_vip_cti_sw.tcl"
displayName="cti_driver"
version="13.0"
description=""
tags="SW_DRIVER_OS_TYPE=hal /// SW_DRIVER_ASSOCIATED_HW_MODULE=alt_vip_cti"
categories="driver_element"
type="com.altera.entityinterfaces.IElementClass"
subtype="com.altera.embeddedsw.bsp.elements.IBaseSoftwareElement"
factory="EmbeddedSwTclDriverFactory" /> - <plugin
name="cts_driver"
file="control_synchronizer/full_ip/control_synchronizer/alt_vip_cts_sw.tcl"
displayName="cts_driver"
version="13.0"
description=""
tags="SW_DRIVER_OS_TYPE=hal /// SW_DRIVER_ASSOCIATED_HW_MODULE=alt_vip_cts"
name="itc_driver"
file="clocked_video_output/alt_vip_itc_sw.tcl"
displayName="itc_driver"
version="13.0"
description=""
tags="SW_DRIVER_OS_TYPE=hal /// SW_DRIVER_ASSOCIATED_HW_MODULE=alt_vip_itc"
name="swi_driver"
file="switch/full_ip/switch/alt_vip_swi_sw.tcl"
displayName="swi_driver"
version="13.0"
description=""
tags="SW_DRIVER_OS_TYPE=hal /// SW_DRIVER_ASSOCIATED_HW_MODULE=alt_vip_swi"
name="vfr_driver"
file="frame_reader/full_ip/frame_reader/alt_vip_vfr_sw.tcl"
displayName="vfr_driver"
version="13.0"
description=""
tags="SW_DRIVER_OS_TYPE=hal /// SW_DRIVER_ASSOCIATED_HW_MODULE=alt_vip_vfr"
Updated 2 months ago
