Knowledge Base Article
Why does the VIP suite CVO II IP have no output when video in and out use the same clock?
Description
Due to a problem with Clocked Video Output (CVO) II IP in Quartus® Prime software version v16.0, the CVO II IP may not generate output if the "Number of pixels in Parallel" has a value larger than 1 and the "Video in and out use the same clock" option is enabled.
Resolution
You can disable the "Video in and out use the same clock" option and manually connect the source clock to is_clk and vid_clk ports.
This problem is fixed starting in Quartus Prime software version 16.1.
Updated 1 month ago
Version 2.0
