Knowledge Base Article
Why does the Timing Analyzer report minimum period timing violation in the Intel® Arria® 10 Native Fixed Point DSP IP?
Description
A minimum timing period violation may be seen if the DSP block is not fully registered.
Resolution
To work around this problem, enable the input, output, and pipeline register using the IP GUI to ensure timing is met when using the Intel® Arria® 10 Native Fixed Point DSP IP.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
