Knowledge Base Article
Why does the Timing Analyzer display data signals as base clocks in the Clock Network Viewer?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.2 and earlier, you might see that the Clock Network Viewer in the Timing Analyzer incorrectly displays certain data signals as base clocks.
This problem arises when the Timing Analyzer detects an SDC constraint defining a clock that fans out to both data and clock ports. It is important to note that this behavior does not impact the timing analysis of the related paths.
This problem only affects Stratix® 10 FPGA devices.
Resolution
It is safe to ignore clocks originating from data pins, as reported in the Clock Network Viewer.
Updated 3 months ago
